Hymer 654 Motorhome bumper
magnum
Lancashire
Autotrail apache
14 months
Morning all, does anyone know how to remove the small part of the rear bumper?? I managed to get the two screws pictured out but it must be fitted somewhere else.
Also the trim part of seal is brittle, can this be purchased. If so from who.
Thank you for your help.
Magnum.
Sadly it's all one piece of the bumper so you'll need to take the whole thing off.
Trim you can buy by the metre from Hymer dealer.
Barrie.
Listen,it’s dead easy!!
Arm yourself with a hair dryer to heat rubber seal.....lever with a small screwdriver to reveal screws.
Bumper may be built in 2 parts👌
Good morning Razamataz,
I can't swear to it but I do believe that corner part with the rubber insert is part of the actual bumper which is actually TWO halves, my right hand half was removed 2 years ago for a small crack to be repaired and that corner piece was still attached to the main half part of the bumper whilst it was repaired and sprayed. Hope this helps you. GWYNTAXI.
It helps if you use your 'old' rubber seal to make correctly positioned holes in the new rubber seal before fitting.
Thank you all for your input.
Kind regards Magnum
