Merdymort
- Sep 6, 2021
- 26
- 4
- Rapido 7063f
- Recently changed from Transit Campervan
Hi all (again ) just trying to figure it all out still here. Got a rapido 7063f, 2006 with the above truma water heater. As far as I can see from the internal dials this should work on electric. I am just in the process of cleaning the water system, the puriclean is in the tank, the cold water runs fine out of all taps/shower and now I just want to make sure itās run through hot water boiler and those pipes too.
I have plugged van in, turned dial inside to hot water but thereās no water coming out of the taps when switched to hot, even after waiting 30 mins. Help please, what have I missed?
There is a red switch at the side under a sliding coverā¦ doesnāt seem to have an off or on tho???
Also, assuming I get it all working, when I want to empty it all out of the water system do I need to use the frost dump valve to ensure none left in boiler or is it enough to just run the water out?
