funflair
For this "how to" guide I needed a willing volunteer with a big heavy van to get stuck in a field thanks @KayeB for being that volunteer, as the car wasn't in the back it was about 6.5 tonne.
The venue was Shrewsbury at New Year, you all know how much it rained at New Year so there should be no doubt as to the quality of the mud. We drove off OK but are 1 tonne lighter and had a drier spot.
If you are going to try this yourselves it is worth investing in a full set of hydraulic jacks and some big pieces of wood, luckily on this occasion I just happened to have some half sheets of 18mm ply in the garage (as you do).
Method
1/ Get stuck, this is the easy bit especially trying to go up hill.
2/ Jack the driven wheels fully off the ground to enable the wooden boards to be placed under the drive wheels.
3/ You will need a second board to drive onto to allow the original one to be moved and driven over again, at this point the boards should be overlapped to stop the wheels dropping through the gap.
its always worth having at least one person stood watching!.
4/ All going well until the boards get chucked out from under the wheels so then its back onto the jacks to get them back under.
We also jacked the front wheels and put them on boards just to let them roll a bit easier and reduce the tendency to spit the boards out from under the driven wheels.
5/ Drive out to huge round of applause, OK the camera person has lost interest by this time.
Conclusion
1/ Dont park your pride and joy in the mud unless you have a "get out plan".
2/ Jacks have more uses that just levelling up so that you can get more wine in your glass.
3/ Carry some sheets of 18mm ply in the garage and it will come in useful "one day".
4/ The boards should have some grip on the mud side to stop them spittting out from under the wheels.
Thanks to Kaye and Dave @KayeB for donating their Concorde for this exercise, thanks to Jim and Julie @jimcunliffe for their help and encouragement thanks to Jen @funflair for the photos (where is the final one on the road!!). And finally thanks to Shrewsbury show ground for letting us make a mess of their field (oops, they dont know yet) but I did stomp on the divets.
Martin
Just in case you think it's still stuck there.
Method
Conclusion
Martin
