Sorry for daft question but I can’t find the switch anywhere to turn this light off. Any ideas please 2012 Autotrail Arapaho
Probably has but is now fumbling around in the dark trying to find the switch again to turn them back on so he can see what he's doing!Well ??? Have you switched it off, or do you need more pointers?
Many thanks, I'll have a look at that tonight then!Just re- read the original post. We have the same van
The switch is above the hab. door, between the heater control and water heater control.
Simples.
The dining area strip stays on even when on dimmed setting but I think now sorted, accordng to another member it's one of the switches on the heater control unit. Can't believe I hadn't noticed those, durrhhh!Barney Rubble
Assuming you have an EC480 panel (probably above your hab door) it's this one. Pressing cycles through bright \ dim \ off.
Well it does on our 2013 Savannah.
comes on with master switch, think I've found where the switch is now!Might be a daft question - but how did you turn it on in the first place?
