How do I fit Truman reducers
Darlington
Pilote
Since 2009
I have a problem with the truma warm air heating the rear of the Motorhome resulting in condensation running down the wardrobes.
Spoke to the dealer as this is the vans first winter outing with no help.
Spoke to Truma who were very helpful and suggested I fit restrictions into the ducting as this would force the air down the bedroom ducts but where do they fit any help would be grateful.
Are you saying that you want more hot air going to the area that you have condensation?
Heat causes condensation not cure it.
These would work. If you fit one at each outlet you can restrict the air leaving each outlet as desired forcing the air to come out of the open ones.
I found we had condensation in the wardrobes of our old Exsis I to cure it I lined the outside walls with some foil backed rubber camping ground sheet and that solved the problem👍😊
Thanks folks but enough heat at the back of the van will prevent condensation as the vents are designed for best cure is not to buy a pilote Motorhome
