Hitchman 40L Aquaroll inlet diameter size?
  • Thread starter Thread starter 82125
  • Start date Start date
8
82125
Im just ordering a transfer pump for the Aquaroll ive ordered.
Ive found a 51mm diameter pump with a higher flow rate compared to the usual 38mm pumps, but will it fit the opening in the aquaroll anyone please?
Aquarolls come in two different hole sizes, although I imagine new ones will have the larger size.
Are you in a rush? I'd wait til the Aquaroll arrives and measure the opening. You can get the right pump off the shelf at an accessory shop or within 48hrs online.
I had a even older 32l (possibily 40+yr) with the small hole, only seen large one with large one ( as SWMBO would say)
We've got about 12-15 of them. All 40 litre with a mixture of hole sizes. Not sure if it was an option, or just a product improvement over time. Large hole ones are much nicer. You can get pumps into them and tap caps.
