Hi its only coming on when I run the taps hot or cold and then of when I turn off the taps cheersLooks like a blown fuse warning, not sure why it'd only come on when running hot water though.
Hi pressure does drop a little bit and kicks back in I'll have a look tomorrow and let you know cheersDo the taps run normally?
Best I can think of at the moment is that the fuse for the water pump isn't making good contact in the fuse box. When the pump comes on, the additional resistance (bad contact) means there is a voltage drop across the fuse that the control panel is reading as a failed fuse.
Try pulling the fuse and reseating it?
Hi thanks for the help I'll have a look tomorrow cheers and let you knowAgree warning light is showing blown fuse. Have you checked ALL the hab fuses?
