Help with Burstner Delfin (Renault master) starter battery
Manchester, UK
Burstner t700
Early 2019
Installed a 2 port solar controller 1 port for leisure battery the other for starter battery.
Can I remove the 2 cables on the E box and extend them onto the spare port on my solar controller?
I need to have a look on mine later, but there is a position on the front of the eBox where you connect the solar input to and the eBox sorts it all out for you.
Hiya
I have seen that, thought is was for a solar panel not an input from a controller
Yeah, you're right TONCAZ , I just saw "solar" and jumped in with both feet !
My solar has the Schaudt LR 1214 controller and I just took it straight to the eBox.
:( I soooooo wish I understood this thread. :unsure::confused:
Thanks for that, does that do both batteries, as I have already wired the MH battery to one port of the dual controller and thought I could use the existing cable to the starter battery from the Ebox, may have to get multimeter out and do a bit of continuity testing.
Thanks again Tony
It does charge both, the leisure batteries get the most charge and the van's battery gets a trickle charge if I remember correctly.
