Have recently had 2 110ah lithium batteries fitted under the passenger seat. Also fitted there is a Victron Smart Shunt and Victron B2B charger. I also have a Victron MPPT solar controller and a Victron IP22 mains charger. The Victron Connect works fine and I‘ve changed the default passwords and the listed names of the devices.
I’ve been reading the Shunt’s manual and, so far as I understand, it can monitor the leisure battery and, by way of the auxiliary lead, the vehicle battery. However, when I read the display on the app, it shows the state of charge etc of the leisure battery and right at the bottom of the display it shows a small voltage (less than 1 volt) as an input, to the vehicle battery. I wish that I had taken a screen shot of the of the display whilst I was at the van this morning. I should also mention that there is a Battery Master fitted (years before the lithium gear).
Anyway, my questions is this: as there are 2 leisure batteries, I assume the Shunt sees them as one battery so gives only one State of Charge (SOC). If that is right, shouldn't the auxiliary lead give the SOC for the vehicle battery? How, apart from accessing the vehicle battery by raising the carpet and cover and using a meter, can I monitor the SOC of charge of the vehicle battery?
I’ve assumed, perhaps wrongly, that the small input voltage was the Battery Master voltage going to the vehicle battery.
Thank you and apologies in advance if I’m being stupid in my assumptions/understanding.
