Picked the motorhome up from storage and should of known things were not going to go well as it would not start because of a flat battery. Not normally a problem as 150w of solar with a 70/30 split between the batteries, oh well jump started it and off we went.
Arrive on site put the fridge onto gas, alarms sounds and it would appear fridge will not ignite. Any ideas?(gas is getting to the hob)
Tried to put water in kettle normal spluttering of the tap as has been drained dow,n eventually water arrives ( still spluttering) but pump will not turn off it appears to be drawing in air and hence no pressure build up to stop pump? Any ideas?
Thanks in advance for any help.
