Help please
Rapido
Hi all
I have a rapido on 2012 I have broken the door handle anyone know where I could get one from.
Is that a cover, how is handle attached?
Not not able to get a 3d printed one you might find someghing on olearys or coastal caravans
It doesn’t look very broken can you highlight the damage
I would think that the OP's photo is from a photo of another van with a non-broken handle for reference. :unsure:
The reason I asked is we had what might have been a similar experience on ours
Our handle screws through plastic covers which was the bit that broke on ours not the actual handle
Terry gave us a temporary solution by leaving out the broken plastic cover and we haven’t really missed it for about 7 years now
Edit - just spotted my reflection, that’s what it is I haven’t had it wrapped 😁
That's after I put it back on. It looks like it has broken before it was full of clue.
I will post more pictures when I get back to the mh
I could probably make one for you. Can you let me know the length of the pull handle. Also, is that only part of the handle. Is their another section that’s not in the photo.
Cheers PaulandChrissy
If you don’t have any luck an easy repair would be to glue the parts back together with superglue or similar to reform the handle shape then cut three pieces of something like coat hanger wire to lay the full length of the handle from screw hole to screw hole bending slightly if the handle is curved then mix up some fibreglass resin and the pour in the handle recessed part of the handle covering the wires, once set this will reinforce it permanently.
I could send you the items, they is a cover that goes over the top of it. Pm me with a price I'd you don't mind
It has been glued before.
Yes I saw that, but with this way the existing plastic is only a mould for the reinforced plastic resin, similar to a reinforced concrete beam but on a very much smaller scale, but if you can get another printed all 👍
