We are in a bit of a pickle as atm we are living in our MH while work is getting done to our house and all of a sudden our Truma C 6002 EH has decided that instead of producing nice hot water , it will produce water at the sort of temperature that you would get in a freezer , BALLL FREEZINGGGG!!!!!
We are running it on Gas.
The heating ( hot air ) side of the Truma seems to be working ok , ( I'm not convinced its 100% as warm as it used to be but that could be due to the cold wind / weather atm )
However when you select just the hot water ( either 40 or 60 ) you just hear a click from the heater unit ( the usual click it would make during its boot up cycle just before the burner lights up ) the nothing , and if you go outside you cannot hear the burner burning , mean while inside at the Truma control panel there are no red lights , just the green and the orange.
If you put the heater onto Heating mode and hot water mode the burner will light up ok and the heating will work ( as above I'm not convinced its 100% as warm as it used to be ) and the water will also SLIGHTLY heat up just enough to take the chill out of it , but not even make the water luke warm.
The above is all on gas usage as the gas side of the Truma is all we ever use.
BTW our gas system is a Gas It refillable system.
