HELP HELP HELP FRIDGE NOT WORKING (1 Viewer)
Mar 21, 2010
2,486
2,993
PANIC off on Thursday. Fridge not working on Mains. Gas or battery. Gas and electricity all working elsewhere in van. Have checked fuses. any suggestions
colyboy
Feb 24, 2013
13,088
101,491
Bolsover, Derbyshire
Hymer S800
not long enough
make model and age will help the diagnosis
you have already tried switching everything off and on again I presume (y)
colyboy
Mar 21, 2010
2,486
2,993
RMT 7651L Tall Refrigerator and oven. Gas not working on oven but working on gas only hob
colyboy
18,034
48,139
Murvi recommended me this guy in Exeter as a fridge expert.
Phil Chapman 07900 297 879
I haven't used him myself directly but Murvi got advice from him to sort out a problem I had on my fridge. I believe he has a reasonable call out charge.
MattR
4,105
38,980
Beds
Panel van
Years
Just checking that the gas supply is on to the fridge, that the trip swich for mains power is live and the 12v supply fuse is intact (there may be a separate fuse at the leisure battery control panel for the fridge). Any indication of power getting to the fridge at all?
colyboy
Mar 21, 2010
2,486
2,993
No power getting to the fridge or the oven which needs electricity ignite the gas.
Oct 29, 2012
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
you say the oven not working.check the igniter fuse as the fridge may be on the same fuse and if the igniter is not working the fridge won't operate
Feb 16, 2013
19,738
52,048
uttoxeter
ambulance conversion
50 years
Are you level, seems to make a lot of difference to some fridges.
Jan 28, 2008
10,117
18,385
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Probably need 12v for any of the power sources to work so i would check that first unlikly to be a gas problem as the mains should still work
colyboy
Mar 21, 2010
2,486
2,993
What great lot of MH Funsters we have on this site. All your suggestions were excellent and with your help and advice I have been able to find the fault. The fault was near the fridge burner unit, one of the cables had worn through and just needed connecting to each other.
Thanks again
colyboy
