Heating & hot water not working
Swift
The heating and hot water are not working in our van. No lights coming on for them at all and there are 0 amps showing on the control panel. Everything else working: fridge etc
Any ideas?
Hi Sam.
Just a quick note to let you know that you aren't being ignored. Your post has only just gone live. We manually review and approve new members' first few posts containing links to ensure they aren't from spammers. Your post has just now been approved and is now visible to everyone.
Thanks for your patience!
There may be a power supply fuse on the 12v habitation fuse board that is faulty , or it could be the 12v fuse that is under the wiring cover on the boiler that needs replacing.
Any ideas?
If it’s anything like ours - if the input voltage from the mains or solar are outside certain parameters it won’t work
If you unplug mains does it work- similarly if you disconnect solar
We have had this on a few sites where the mains voltage was a bit low
Looks to me like the controls are between settings.
It might be worth waiting for the OP to return before spending too much time on this.
