Head lamps A Class
England, UK
Learning all the time
We have an A class. The head light lens are getting a bit scratched with age. Look a bit sand blasted.
Any way would the lens be a Mercedes thing or a Le Voyageur thing?
Often see adverts for headlight cleaning, especially used to see it in Spain..
Also lots of videos on youtube, so could that maybe cure them ???
Definitely don't have glass fronts will get a photo in a bit
I think Mercedes on Le Voyageur but yes a photo would help and yes they might polish up.
Not the best pic
Look like plastic should come up nicely with a Headlamp restore kit Quixx are about the best. Ignore anyone who tells you to use T Cut/Toothpaste/Rubbing compound, they will just go again in a few months you need a UV sealer to keep them bright the Quixx kit includes one.
Amazon product ASIN B00BHUPHSC
Thanks will give it a go. Nip over to Jeff's corner shop (Amazon) and order some. Will get a better before and after pic. Also yep definitely plastic
Upvote 1
Looks like 00-07 sprinter unit, non genuine £80 each On eBay. I would remove unit check mounting points against photos if looks ok order sale or return.
Now have a plan B. Years mentioned are right
Thanks all.
DandG5515 do you have an ebay link. Never use ebay would not know where to start:confused:
Sorry not good at links, I would try with a phone, photograph the back of unit to see if Hella part number Google or eBay search will produce pictures of the back of the light unit to see if mounts look right. Not sure if a slight difference between 2000-2002 and 2002-2006 unit. Best to work of part number if possible. Good luck.
