Hi I want to buy a small portable generator to charge my motorhome every couple of weeks it’s a swift motorhome. I started looking at generators and it’s a complete mine field any advice would be appreciated
First work out the largest current the batteries will take. Add up the total Amp-hours of the batteries and divide by 5. For example, for 200Ah of battery, the max current is 200/5 = 40 amps.What is the best way to use a generator to charge the batteries? Plug into the motorhome and use the onboard charger or use a more powerful stand alone charger ?
Something as simple as this may suffice for your requirements.
4 stroke, economic and quiet when running.
I have one for a different application, but I have plugged a van into it to power the onboard battery charger.
They do them in bigger sizes too.
Nassboards Instant Power Portable Suitcase Inverter Petrol Generator 4 Stroke 2.6HP 800W 12V 230V Amazon product ASIN B07XZMFV5H
Screwfix do a very similar looking one, with different branding.
Error 410 | Screwfix
Thousands of products at low trade prices | FREE next day delivery available | 30 day money back guarantee on all orders.www.screwfix.com
The Hyundai P1 range appear quite popular too, I’ve not used one but have seen quite a few about.
If you look for a Honda Eu10i.....get it from a reputable source as there are hundreds of fake replicas out there![]()
Ours doesn’t in the winter.How big is the solar panel? Do you know that it is actually working? It should keep a battery topped up even in winter.
Might need them for his alarm which with out might invalidate his insurance, don’t know.If you take the batteries home to charge them why not keep them there till you need them ?
We have two 130 panels and they can't give enough juice to keep our batteries charged up in winter.How big is the solar panel? Do you know that it is actually working? It should keep a battery topped up even in winter.
There seems to be a constant 0.3 amps draw on either the leisure battery or the engine battery I know the tracking device takes power I’m not sure what else as this is all new to me this year but learning slowly I have just checked my app 0.3amps being drawn and my solar panel charging vehicle battery 0.3a but later on when there is no sola charge this is when my batteries slowly over a couple of weeks start losing there power
Probably cheaper to buy a generator then to pay an auto electrician to work on the van.Our tracker uses between 0.035a and 0.080a depending on whether it's transmitting it's location, which it does briefly every 5 minutes. Other than that when the main switch is off the drain is just 4ma.
If I were you I'd be finding out what's using the power continously.
Do the maths. A constant 0.3amps is 0.3 x 24 = 7.2 amp-hours over 24 hours, and over a week that's 7.2 x 7 = 50.4 amp-hours. With 2 x 100Ah batteries, they will be down to 50% in two weeks.There seems to be a constant 0.3 amps draw on either the leisure battery or the engine battery I know the tracking device takes power I’m not sure what else as this is all new to me this year but learning slowly I have just checked my app 0.3amps being drawn and my solar panel charging vehicle battery 0.3a but later on when there is no sola charge this is when my batteries slowly over a couple of weeks start losing there power
Of course, no problem, provided it's solar-powered.Will you still be able to use a generator after 2030?
