- Sep 9, 2021
- 331
- 896
- Autotrail Mohican S
- Have owned my moho for 2.5 years now
Has anyone got any experience of the above
Thanks good to hear it seem accurate. not too concerned about cost lolYes I have a unit on both bottles. Seems to be accurate but way too expensive.
Just make sure you do have the newer type bottles as the wave unit will only work with the multivalve bottles. Chances are that is what you have but always worth checkingThanks good to hear it seem accurate. not too concerned about cost lol
yes new type bottle system only fitted monday lolJust make sure you do have the newer type bottles as the wave unit will only work with the multivalve bottles. Chances are that is what you have but always worth checking
As far as I am aware they read the amount of liquified gas in the cylinder and with an 80% fill it will read 100% when full as mine has proved on refilling so it’s accurate enough for me how accurate do you require it to be?I’ve read a few reviews of the ultrasonic type sensors that attach to the bottom of cylinders stating that they are not designed for refillables due to the internal 80% cut-off float giving false readings. Anyone have experience of that?
what batteries do they use out of intrestI have had them on both cylinders for about 18 months. More than happy with them. Seem accurate. Batteries need replacing every 7-8 months.
AAAwhat batteries do they use out of intrest
Monzer. When you say newer bottles, what age bottes are you referring too, please.Just make sure you do have the newer type bottles as the wave unit will only work with the multivalve bottles. Chances are that is what you have but always worth checking
I'm not sure when they were phased out but they moved on to multi valve bottles and the older bottles can't have a wave system fitted.Monzer. When you say newer bottles, what age bottes are you referring too, please.
Another very satisfied Mopeka customer. Now £100 for a pair , gaslow £118 each
Amazon product ASIN B083RCD8KZWhere is that from please?
Mopeka work on any steel gas container: calor butane and propane , bottle and underslung gasitwould these work on gasit system. I find the little magentic ones they supply just show full or empty
monzer Mine are on twin 11KG Gasit system older type cylinders and are working wellwould these work on gasit system. I find the little magentic ones they supply just show full or empty
I bought so Mopeka pro sensors from AmazonAmazon product ASIN B083RCD8KZ
First one on search may get it cheaper
I can't seethe url
Twas amazon
Yes and you could get PaulandChrissy to make some cradles to fix to the bottom to hold them if you get the round Pro versionDo the Mopeka ones work on Aluminium bottles. Aside from the attaching them problem.
Just ordered the Mopeka pair above.
It’s a shame they can’t be turned off, or have remote batteries fitted, due to them not being required most of the time, and requiring cylinder removal for battery change.
