Gas isolation valve nut!
Leakylunar
492
628
East Yorkshire
Just looking
One a newbie
Hopefully someone can help, I want to add bbq point to a spare isolation valve but when I looked yesterday the silver nut
Is missing ( obviously thrown out with the grill!) can you get new ones if so where from?
As Pappajohn said, take one with you if you can.
Otherwise just measure it and go to a merchants and tell them what you need.
Don’t forget to check for leaks with some soapy water, or do a drop test if you have a gauge.
Give me a call at Autogas 2000
Just a quick update got hold of correct nut/olive for the truma isolation valve but did take a lot of tightening!
Can’t find any leaks but going to either fit gas stop valve( don’t know if they work)
or try and find someone to do a gas check.
Although I haven’t fitted it yet I’ve got special olives to use with Truma gas manifold which I was told to use
As suggested give Autogas a call, they have everything :giggle:
Truma use special shaped olives & nuts.
LES
Yes I found that out, normal olive couldn’t stop it leaking! Then I remembered the olive I got with the nut😳
