Mine is a black one with a red knob. If it's fed from the hab battery does that mean the 12v switch in the hab area needs to be ON for the frost valve to function? (I mean the 12v kill switch on the control panel with remaining battery powers and water levels)If your valve is a black one with a red knob it will be fed with 12v from the hab battery.
Newer ones with a blue knob & button are mechanical so no electrical connection.
Normally they are wired to a permently live output on the distribution unit so you can turn the panel off and they will still work.Mine is a black one with a red knob. If it's fed from the hab battery does that mean the 12v switch in the hab area needs to be ON for the frost valve to function? (I mean the 12v kill switch on the control panel with remaining battery powers and water levels)
