Hi friends, anyone out there got a benivan 122 2019 ,l was in carpark at brownhills yesterday and someone very kindly took my freshwater drain pipe and tap.just wondering if the pipe would be same gauge as b&q,cos l have actually got a spare tap
Thank you for your helpTaken or just dropped off? It happens.
And yes, you'll find something suitable at B & Q or a good plumbers supplier.
Nothing to prove unfortunately but yes in their carparkSomeone stole your freshwater pipe and tap while you were at the dealers ?
It's the pipe from the tank and the tap ..it sounds like it's 28mm pipe and elbow, I've got a spare tap which l will use.If it's the same as our Chausson ( both trigano group) you just need a push fit stop tap. Ours originally came with just a 15 mm push fit stop end but they're not really designed to be used repeatedly. Unless your tank was empty there would have been an awfully big puddle underneath when you got back!
Unlikely for a freshwater tank do you mean a waste water tank?It's the pipe from the tank and the tap ..it sounds like it's 28mm pipe and elbow, I've got a spare tap which l will use.
The tankwas actually empty,as was the waste as wellIf it's the same as our Chausson ( both trigano group) you just need a push fit stop tap. Ours originally came with just a 15 mm push fit stop end but they're not really designed to be used repeatedly. Unless your tank was empty there would have been an awfully big puddle underneath when you got back!
No,waste etc is still in site,but advised today that 23,25,32mm are all available from many places,but 28mm is as rare as rocking horse poo.however hopefully Sheffield caravans carrya good supplyUnlikely for a freshwater tank do you mean a waste water tank?
