Fresh water beeping saying low water, when its full. (1 Viewer)
GeraldineM
Putney, London, UK
Fiat Swift Freestyle
Since 2017
Hi our motor home continuously beeps when we turn the water on and says the fresh water is low. Even if we have just fulled it. Any suggestions? We have to turn the water on, use it, then turn it off again! It’s driving us crazy!
Apr 22, 2018
6,533
12,029
Herts.
Adria Coral lowline
Listing what control panel, and what van you j
have will help responses
Has it always done this? New to you?
Some systems you can calibrate. This is done when empty or full depending on what you have.
Sep 3, 2012
7,049
23,112
Cheshire
C Class Elddis 175
8+ years
You can recalibrate the level but you need to advise what control panel you have ,what van etc.so peeps can help
huck999
262
481
Crewe, UK
Dethleffs Trend
It sounds like the level probes are not working correctly. The probes can lose their conductivity, especially if you normally fill up in a hard water area., a bit like your kettle.
The probe are probably similar to this:
Try sloshing cleaning fluid (something like Puriclean) around in a half full tank, by driving around for a bit. Top up tank to full and leave for about 24 hours.
Empty, refill and recalibrate (if yours allows that) the sensors.
Good luck
