Fitting fridge MH 1210A stat .
stoke on trent
relay lwb pvc
6 years
Have now managed to fit MH1210A control stat (to fans ) by putting probe in through back of 3 way fridge through same hole/route as original stat and clipping to freezer fins next to original probe ,What Temperatures ( cut in /out ) do the MH stat need to be set at?
If you are attempting to control ventilation fans installed behind the fridge the sensor needs to be behind the fridge and ventilation fans. Definitely not inside the fridge.
Thanks for answer -where do you suggest fitting the probe then and what temp settings ?
My probe is behind the fans (but out of the draught they create). It's mounted on the same bracket between the two. My temperature control has no markings so it's adjusted to come on when the weather is pleasantly warm and the fridge is down to temperature.
