I'm going to order the Jabsco mini as the reviews say it has much stronger connections than the cheaper accumulators.
It looks like this.
Its ok if you have the flexible water hosepipe fittings, but life is not that easy!
The fittings leaving the shorflow pump are the solid type with push fit connectors, image below.
(BTW, the cassette is just a spare that I carry, nothing to do with the actual loo)!
The red and blue pipes in the foreground are leading to the external shower fitting. I thought i could connect into the blue pipe and fit the accumulator here.
I need to convert and connect into the more solid type pipes. What fittings do I need to buy to connect into my system?
Any pointers to fitting, greatly appreciated.
It looks like this.
