Fiat Ducato Low Beam Relay Supplier 2.8 Jtd 2006
West Cornwall
13 Years, 20 years with a caravan
Hope someone can help my low beam relay has failed tested no output. I tested with one of the other relays and low beam worked. The problem I have is finding a source for the relay. It is a Bitron 12v 20a 4 pin relay B047 E 46520411 232006. I tried a universal relay 12v 24a 4 pin but no luck. Any help would be appreciated.
Phil.
Broken Link Removed
The 30amp red relay should work equally well but much cheaper source and NEW
Broken Link Removed
Thanks Andy. Will purchase and let you know the result.
Phil.
Andy,
Relay arrived this morning fitted and dipped lights now working. Thanks for your help.
Now about to sort out the reversing switch ( loose wire ) so under the van I go.
Phil.
Phil.
A long shot but, can you remember where the relay is located? Boycie
I'll have a look and get back to you.
Phil.
Check relay T02 located under the bonnet on the right hand side fuse box.
Phil.
