Fiamma safari room on Omnistore awning ??
Jaws
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Sooo.. I have an Omnistore awning on the new van.. But a Fiamma safari room ( clip system )
As far as I can work out I SHOULD be able to fit it by just fitting the Fiamma locating widgets both top and bottom..
Anyone ever done this ?
Omnistor groove is 6mm Fiamma 4mm
I imagine an adapter of some sort is available
Ahh.. I seem to have found the answer ! There is a kit available to do the job !
Stand easy one and all !! :Wink::thumb:
Dunno if I should LOL !!!
Here is a link....
Broken Link Removed
The adaptor kit and parts are supplied free with the privacy room, unless you bought it second hand. However, you WILL need to reduxe the length of the two aluminium clips by about 50mm, using a hacksaw and template that is also supplied in the kit.
I use a Fiamma on my Omnistor Awning and it is fantastic! Once you have mastered how to put it up, lol, but just google Fiamma Privacy Room and you will find loads of videos showing how to do so, and you won't need any written instructions from then on.
REMEMBER that the awning support legs will be OUTSIDE the Privacy Room, once converted. There are velcro strips provided in the kit to fasten the room corners to the legs!
