Fault codes for Ducato including Fiat
Northampton
Rapido & Bongone
Ive added a new resource
Fault codes for Ducato including Fiat and generic compiled from a number of different sources .
you may see the same code repeated with a different description.
If any one has access to a fuller or definitive Ducato list please add.
Hi have you got a list of fault codes, and could you please recommend a fault code reader for fiat ducato 160 multijet.
Thanks Steve
Thanks Steveu
Multiecuscan from Gendan in Swansea is a free download and £120 I believe for a subscription to access all options.
That includes the need dongles to fit your model which they also can supply.
It is very good and used by many proffesionals.
It is Fiat and Alpha specific.
Also works for many of the modules on my citroen relay (it has a different engine, but many of the other ECUs are the same).
Stevelacoste
As my post, the list is in the resources area
I use multiecuscan on a win 10 laptop and a obdlink sx usb cable and AlfaOBD on windows and android on a Samsung phone with The orig SX adaptor and a micro-usb adaptor.
There are shedloads of cheap ELM327Bluetooth adaptors that work with Generic OBD but not specific Fiat codes and PIDs.
OBD-II PIDs (On-board diagnostics Parameter IDs) are codes used to request data from a vehicle,
The recomended BT adaptors can be upwards of £50 or a tenner if you are lucky.
Recently i seen a french video using Mes and a BT adaptor same as recommended by alfaobd and Kapron The Vgate-iCarPro £24 from ebay
I have used this with both multiecuscan, alfaobd and torque pro.
Torque will only give generic info. My preference at home Is multiecuscan in van at all times alfaobd and obdlink sx and torque bt dongle showing speed and temperatures and voltage etc.
