I did have a 100 watt panel on my mh
The mppt controller is fitted above the oven in my tec tower for some strange reason . The cable to my battery bank is 4mm which is routed down the back of the fridge down to the chassis then into the battery's a run of 6.5m.
I have fitted two new 175 watt panels
I Intend to move the mppt 100/30 amp controller into the battery compartment and connect to the battery with 16mm cable .
What cable should I use to connect to the solar from the panels which will be 6.5m
