eura mobil parts (1 Viewer)
Jan 30, 2012
76
47
doncaster
a class
Hi funsters,
I wonder if anyone can give me some advice. I have a eura mobil 810 integra. Im having trouble operting the front electric blind. This is because the switch is badly warn and works only intermittently. ive tried to get a replacement but, have been told that the part is no longer available. My question to you is, do you know where i can get a set of switches like these or do you know anyone that can repair the ones that i have. Its in a set of switches but only the blinds switch is duff. See photo attached.
attached.
308458
bobski
Jan 30, 2012
76
47
doncaster
a class
no i have'nt jock, i just took the dealer at their word. i'll google cbe and try that. cheers feller!!.
JockandRita
11,913
159,267
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Sorry Bob, my red link wasn't working before, but it is now. You may find something in there.
Good luck. (y)
Jock. :)
denisejoe
5,765
14,811
Warden isle of sheppy
Since 2004
There are pressure switches at the back had to get mine changed they are cheap on Ebay but need soldering in, the panel comes out easy and disconnect the wires find some one good at soldering will try to find switches on Ebay for you
denisejoe
5,765
14,811
Since 2004
Can’t find them but @Techno was the one who told me what they were called current only flows when you apply pressure to them
TheBig1
Nov 27, 2011
17,851
44,361
Yes but with a little work you can replace it with standard switches, both latching and momentary push to make
bobski
Jan 30, 2012
76
47
doncaster
a class
I'm going to see if CBE have one in stock first. Did you replace just the blinds switch?, if so I can solder so that would be next option. I need to get the switch bank out for a look at the back. Does it come out in one piece?.
Feb 5, 2009
696
804
South Essex
25yrs in Motorhomes and Caravans before that
Hi Bob
I have the same van as you I think...
My van has had a standard Thule step switch fitted on the drivers door post at some time in the past to operate the windscreen blind
Having said that, I have had a problem with the CBE electric step switch by the door and have just found and replaced the SPST circuit board switch myself. Like you I was really apprehensive about doing so, but was quite easy in the end. I had to buy a pack of 10 switches (tiny little things) so have some spares if they are the same & you need them..
Steve
Feb 5, 2009
696
804
South Essex
Just to confirm, these are the ones I used on the CBE step switch by the door
Link Removed
Hope this helps
