yourself would be a good start you would know it was fitted right and saver yourself a fortune, or put two on with the money saved.any recommendations for someone to fit a solar panel in Essex ? Cheers Mick
get flexible , only stick them down then only need one small hole for cables, plenty ways of sealing that.I was planning to but The bit that freaked me is cutting through the roof Ha
Had two on our last van three years no bother, but have the other sort on this one as it was right cheap but even so only four Tec screws to hold it down@chaser there seems to be a bit of a problem with some of the flexi ones.
The panels need airflow underneath to keep cool, which these flexi ones dont have, and are causing failures.
Well documented I believe.
