Ellidis warranty? Is it a joke?
South Wales
Swift Escape Compact
Since 1988
In November we bought an Elddis Accordo based “Majestic”.
We love the motorhome and have found little to fault but, during the recent very wet weather, we found rainwater was being blown past the top seal on the rear “garage”. We checked each day, wiping up any water that had got past the seal, (never very much).
We took the motorhome to our local, trusted, Approved workshop in order to have the seals renewed, under warranty.
Today they rang us to say that Elddis had refused the claim as damp meter readings were low and no damage had been suffered “as yet”.
The AW explained that we had found the problem early and had dried the area daily, but to no avail. Apparently we have to wait until any water ingress causes damage before they will authorise a repair.
Surely it would be better to catch any problem early?
It seems an odd way to do business.
Not sure what yours is like but i had this issue on my Rapido and i purchased some extra rubber seal that i fitted into a slit around the outer edge of the door This sorted my issue out 100% i know you shouldnt have too but maybe worth it to protect your MH and stuff in the garage
Fiamma drip stop or aluminium 'J' rail run along the top of the garage door will divert the majority of rain water { bit like a roof gutter }.
What an utterly pathetic response. Carthago insist on a drenching test before handover and again after a few months to make sure there are no leaks that might cause damage. I despair of the attitude demonstrated by some manufacturers, do they care nothing for their reputations and long term viability. Obviously not.
if Elddis refuse tell your supplier you want it sorting by themselves they sold you the vehicle its there responsibility to ensure the vehicle is up to scratch to start with
Seems like a good plan............
......if the Dealer ever reopens after the lockdown! ;)
Your contract is with you dealer, not Elddis the dealer should make it fit for purpose and sort it out with Elddis afterwards
You are correct. However the Approved Workshop, which we have used for over thirty years, is only 3 miles away and the dealer 80 miles one way. We were trying to avoid a 160 mile round trip.
The AW have always carried out our warranty work on different makes of m/h and are “approved” by Elddis, so were surprised (amazed really) at Elddis’ response.
See also post #6 above.
On our last Hymer we had a leaking garage door seal a UK dealer changed it under warranty, we bought the van in Belgium.
know what you mean about having go to dealer we had a marquis 285 and 140 mile round trip every time in the end I had them collect it from my house as it had to go back to factory once for warranty work ended u with no m/h for 3 months but they don't compensate you either
do the workshop have a solution to fix?
if they do and a price to do it isn’t prohibitive I would get it done and move on
ultimately Elddis will not get your business again, better to preserve your asset today than lose value while arguing a point
shit service from manufacturer though ?
Not in the slightest surprised. When a 5ft chunk of plywood fell off the new Elddis caravan ceiling after just one week's use a couple of years ago, I wrote to the MD of Elddis pointing out that there were two design flaws in this piece of trim. One was using hot melt glue to stick such a long length, and the second was that the support bars for this trim were too short, so that not only gravity but the fact that the trim was forced against the roof light caused it to fail. I asked for both faults to be rectified.
This was refused by Elddis and instead they issued a recall and simply bunged half a dozen screws through the trim and into the roof.
However, events overtook this, and so much else went wrong within the next month of use that I used the Consumer Rights Act to get my money back and buy a motorhome instead.
I have the same problem with my 19 plate brownhills special. Had the hab check done in February damp was found in both garage doors , both are going to be replaced under warranty which elddis have agreed to cover. The join for the seals are at the top of the door why?
One other point, at the weekend I went on to the DVLA website and looked at recalls of my motorhome and yes there is one regarding the brake pipe clips on the bulk head . I haven't heard anything from the dealer, booked into a Peugeot dealer for this week, good opportunity to have a run out.
