Ah I could tell you how to do it on our N+B but your Burstner will be different for sure.thanks for the replies Yes im referring to the heat exchanger
do you need to put the orange switch on beside the heating control panel to work the auxiliary pump?
Well just in case it helps and the adverts are on we have a heat exchanger with a valve on it so the first thing is to make sure it open then we just switch on the heating without gas or electric but the pump running controlled by the thermostat and then set the thermostat.
OK we do also have an auxiliary pump but that is for running the engine water around the heat exchanger to heat the engine from the heating system.
As I say though yours could be different in detail rather than principal.
Martin
