Hi hope you can help .
I have just bought a Hymer Duo S took it for three weeks around Scotland and was brilliant .When I ordered the van I wanted air con as I expect to be in Spain during the summer .Unfortunately as the van had two panoramic ceiling hatches rather than the standard the dealer could not fit a ceiling air con unit . They Dealer also had no idea as to any other Option. I found a portable option coolmycampervan a bit of a pain as will have to fabricate a panel for the sliding window .If I am plugged in on a site not a problem but if wild camping an issue .I though the answer was a second battery ,solar panel and an inverter .
The portable air con uses 1.88 amps 220-240 volts with a power use of 450 Watts.Start up current under 3.0 ams for <1 second.They recommend a minimum 700w Pure Sine inverter.
My dealer quoted me £ 935 for 155w solar panel and £1870 for a 1800w inverter the smallest one they do !
I have an electric fridge no tv and led lights .My heating and hot water is diesel.I am based in the midlands.
Could I have any thoughts or ideas from you on what to do please.
