EHU cable insurance implications (1 Viewer)
GJH
29,450
38,827
None, now sold
2006 to 2022
I kept forgetting to post this until prompted by the other insurance thread and liability risk if you are at fault.
A couple of weeks ago, whilst we were at Blackpool South CC site Jill got into a discussion with one of the wardens about a couple of EHU cables which were in use whilst still partially coiled and the consequent fire risk. The warden told her it was something that happened regularly and that wardens have often faced abuse if they point out the dangers.
Now the important bit. Apparently the CC have taken advice on the issue and have been told that if a fire does occur because of overheating of a coiled EHU cable then the insurance cover held by the person using the cable might well be void and they may be liable for any damage themselves.
estcres
1,300
767
Sunny Bournemouth
coachbuilt
since 2005
The person would only be considered "at fault" if they were aware of the dangers, if they were unaware that such a thing could happen then they can plead ignorance, however, if it was pointed out to them prior to a fire and they did nothing about it then they would be held liable along with everything that that concerns.
As an electrician I am fully aware of the consequences of using coiled up leads and always uncoil mine prior to use, that is effective for all my, at work, home or leasure.
I remember several years ago seeing what effect a wallpaper steam stripper could do to a coiled up extension lead, it all melted and turned into a big lump of plastic and wire.
Another area of liability concern would be if an EHU lead was placed on the ground in such a fashion as to cause a trip hazard. Who would be liable then?
G
GJH
29,450
38,827
None, now sold
2006 to 2022
Granted - but don't leads these days normally come with a warning printed on the packaging?
The person who had left the cable in that way surely?
scotjimland
2,335
10,107
A Woosh bang
Indeed they do Graham, but lots of second hand vans are sold with secondhand EHU cables not in original packaging ..
Case in point.. I bought a second hand caravan last year and it came with all I can describe as a lethal EHU lead.. under sized and with damage to the sheath .. I promptly binned it and bought a new one .. (cheaper than making it up myself) and it did have a warning on the packaging.
sedge
Jul 7, 2009
5,504
13,117
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Bane of my life .... Pete goes potty if I hoover without uncoiling all the wire, it's a PITA when I have eg dropped flour on the kitchen floor and only need a 30 second blast to eradicate it.
I'd been hoovering like that (partially coiled) for 40 years girl and woman without incident. It's OK with the cylinder as that has a button you press and the lead gets 'swallowed' but on the upright it's manual wind and unless you get it 'just so' the peg thingies aren't long enough to keep it in place.
So I generally either don't hoover at all or only do it when he isn't there .... :roflmto:
G
GJH
29,450
38,827
None, now sold
2006 to 2022
Good point, Jim. As a general rule, though, I thought people had a responsibility to ensure tool safety before use or suffer the consequences.
JJ
Mágica
May 1, 2008
19,259
48,046
Burstner Privilege T
over 50 years
My "Hoover" has an automatic wire recoil system and I don't uncoil it fully before vacuuming...
Now, thanks to Funsters, I realise how dangerous this practice has been and therefore I will stop vacuuming...
JJ :Cool:
ShiftZZ
21,383
84,579
Dark Side of the Moon
I'm not so convinced, is this an attempt to 'Nanny state' us all?
Do baths have to have a sticker to say that you may drown if you put your head under water for two long? If you eat too much salt is there a direct warning on the carton, what if you ate the whole lot?
Otherwise the insurance companies could claim that you breached the 175th law of some obscure law of physics or something.
Also I don't think that ignorance of the law is an excuse either.
Thinking about it, if these warnings came into force everything bought would have a lost of what you can and cant do, the list would be huge.
"Thou shall not use thy false teeth to open Brazil nuts"
Waving your satellite dish in bright sunlight may blind next doors cat
scotjimland
2,335
10,107
A Woosh bang
JJ :Cool:
when did you start ?? :ROFLMAO:
but just for your JJ in case you get a sudden urge to clean up, the H&S Advice on vacuuming .. and it's not a joke .. I copy/pasted ..
Method Statement – Suction Cleaning (Vacuum Cleaning)
Equipment:
Personal protective equipment
Warning signs
Suction (Vacuum) cleaner and attachments
Stiff hand brush
Dust pan and brush
Plastic sack
Method:
1. Put on personal protective equipment.
2. Assemble equipment, check electrical equipment for safety, particularly plugs and cables.
3. Place warning signs.
4. Ventilate the area, if appropriate.
5. Adjust height of brush/beater bar to suit surface being cleaned.
6. Pick up any large or sharp items by hand before suction cleaning and place them into a plastic sack.
7. [HI]Full unwind suction cleaner cable before inserting the machine plug into a power socket.[/HI]
8. Cover the area systematically, giving more attention to heavily trafficked areas, edges and corners.
9. Use dust pan and brush to clean under furniture and areas inaccessible by machine.
10. Remove plug from power socket and recoil machine cable.
11. Clean equipment and check for safety.
12. Return equipment, materials and warning signs to store and close the ventilation, if appropriate.
Safety:
o Wear personal protective equipment.
o Check electrical equipment, particularly plugs and cables.
o Do not plug the machine in until it has been assembled and it ready for use.
o Do not allow cable to become taut at ankle.
Care of equipment:
o Empty the suction cleaner/replace bag if required.
o Clean brushes.
o Clean dust pan.
Jul 29, 2007
6,551
39,658
Ipswich
RV and PVC
30 years
Simply using a lead coiled up will have no effect over a short period of time, and using a low power device like vacuum cleaner I doubt would have any effect if used all day.
I have noticed some leads state one amperage for uncoiled and another for coiled.
Ian
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
if you had an RV shifty it would drive you mad
If you owned an RV shifty it would drive you round the bend with the number of warning labels.. mainly because of California law.. everything has a death warning on it... gone mad.
As for the cable on the ground... very much a Tort law argument .. Occupiers liability Act? Do the camp site (running the site as a business and holding themselves by such as an expert) be responsible? should a signed be displayed at point of entry ... Shoe Lane Parking case... Should the warden be required to advise people. if so does he become the 'officious bystander ' and thereby can be held responsible. ? very much a jury question I would think..
I am not offering an opinion other than saying I would earn very well out of it if it came my way.:ROFLMAO::ROFLMAO::ROFLMAO:
Bob
ShiftZZ
21,383
84,579
Bob
Indeed Slob, thats why I would not buy one and try and avoid Americans as much as possible, they themselves should carry some sort of health warning...
Its an American thing you know... I think its called stupidity
scotjimland
2,335
10,107
A Woosh bang
Ian
Hi Ian ..
some while back I was using a small angle grinder on the RV , (not sure of the watts, probably about 350) .. and me being a lazy beggar I only uncoiled a few meters of an extension cable ..Within 15mins or so I saw smoke coming from the real.. when I uncoiled the heat had melted the sheath and it was welded together ..
vacuum cleaners are generally at least 1,000 watt . our Vax is 1300 watt .. so IMO there is no safe current.. the heat is generated not only by the current but by magnetic induction with the real acting like a coil ..
6,551
39,658
Ipswich
RV and PVC
30 years
Hi Ian ..
vacuum cleaners are generally at least 1,000 watt . our Vax is 1300 watt .. so IMO there is no safe current.. the heat is generated not only by the current but by magnetic induction acting like a coil ..
Hi Jim as I said some coils have a coiled rating, 5amps comes to mind, that's 1250watts as you know.
As both positive and negative are next to each other, their is as far as I am aware and have been assured by others including "Boff" on facts no magnetic effect, their is also no iron core, so its only the heating effect. This makes sense as transformers only have a single main winding and an iron core.
Here's a reel for sale on ebay click on the picture and it says 5amps coiled.
Link Removed
Ian
scotjimland
2,335
10,107
A Woosh bang
Link Removed
Ian
putting theory to one side Ian,
I can only say what happened when I used mine with a small load... from that day onward I always unwound.. as they say, an oz of practical experience is worth a ton of theory .. ::bigsmile:
oldun
747
162
St Neots
VW Campervan
Since 2001
What do you mean by a "coiled" lead?
Are you referring to a lead rolled around a drum or to a lead laid on the ground in a loose coil.
I believe that the risks of overheating are much greater when on a drum than when loosely coiled on the ground.
Any information as to overheating when laid in a coil on the ground?
G
GJH
29,450
38,827
None, now sold
2006 to 2022
Both. Tight coil is more dangerous than a loose coil but why risk it at all?
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Short periods of live 'activity' will not heat the lead up a lot, its extended periods like hours that will.
So JJ keep on hoovering:ROFLMAO::ROFLMAO:
Peter
Jan 28, 2008
10,117
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Not sure of the electrical theory bit but work on sites where a lot of leads get used its always the small enclosed reels that burn out my own lead is probably getting on for 15years old has been used with devices up to 3kw regularly and i cant recall ever totally un reeling it and never had a problem but often see the small enclosed reels melted painter using steamers all day i would think
darklord
1,241
1,230
essex
coachbuilt
three years
There is another hazardous item most of us travel with, treat with extreme caution......................
Jul 29, 2007
6,551
39,658
Ipswich
RV and PVC
30 years
When electricity flows through a wire the resistance to that flow creates heat, if that heat can't escape you have a problem. The insulation around your cable is unfortunately a good heat as well as electrical insulator. Tightly coiled in a drum the heat builds, loosely coiled on the ground I would imagine it would escape.
You can see what effect the insulation on a cable causes to its current carrying capacity, by comparing a piece of 15amp fuse wire which has no insulation, to your cable reel which does, stripped of its insulation it might be good for 100amps or more.
Ian
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
As an electrician I am fully aware of the consequences of using coiled up leads and always uncoil mine prior to use, that is effective for all my, at work, home or leisure.
That would seem like overkill if only a low wattage load is connected to a 13 amp lead:Eeek:
Jaws
23,836
72,492
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
This is a real hobby horse of mine, having seen some real tasty fires due to the practice
Woman would always say I am making a lot of fuss about nowt.... that was until she was using a pressure washer in the front garden and had left the extension lead all nicely coiled on its real still
I happened to walk out and saw the smoke coming off it but by that time it was too late to save the extension lead or the door mate the roll had been sitting on !!!
Now she is as concerned as me when we see a rolled up EHU lead, esp in cold weather when the people may well be using a couple of kW fire !!
At a Funster Valentines day meet in the Scunthorpe area I well remember seeing an EHU quietly steaming away to its self ( it was BITTER cold and the dampness was steaming off of it.. )
When I pointed it out the person ( no name no pack drill etc ) said 'Oh, it always does that'
What else can anyone say !!!!!!!!!!!!!!!!!
If we pull on a site and see a van with EHU on a nice neat roll we will always park away from it..
