8
82125
Another EBL problem.
When i bought this 2012 Burstner Elegance i890 despite all the pre-purchase checks having being ticked off as working, Ive had to fix a lot of the allegedly working items myself.
Latest one is stumping me however.
My leisure batteries were not being charged by either the solar or the alternator (ive since fixed the alternator charging which was just the 20a fuse on the engine +ve terminal).
Not so simple with the solar it seems.
Ive checked continuity on every fuse on the EBL220-2, checked the 50a and 2a fuse on the leisure batteries (visual check only was done on these as i didnt want to pull them and could get meter probes on them). Likewise for the engine battery (which is when i found the 20a for the alternator charging had blown). Irrelevant, but the 10a for the fridge had also blown on the EBL so now that works on 12v too (dealership had ticked everything tested as working).
What's next to try please? Are there associated relays somewhere (or is it all handled via the EBL?)
My solar set up is a large unknown 150w ish? panel, a Solar Technology International STCC10 charge controller (pictured below).
As per the picture it constantly flashes the "battery 2" led and never switches over to battery 1 (which must be my leisure batts). Flashing (it says) means both banks are fully charged. Clearly this isnt the case because it continues to do this when my leisure batteries are down to 12v.
The "Sun" led is lit constantly, even at night! Which cant be right.
Ive had digital volt meters fitted to both engine and leisure battery banks and can see the engine battery at 14v at times when im off grid (so it appears the solar is charging the engine battery ok). But im assuming either theres a fault with the solar controller and it cant switch charging to the leisure batteries or it just isnt "seeing" the leisure batteries because the fault lies elsewhere?
Any ideas please? Thanks in advance.
