Motorhomer14
I have a EBL-211 and a lithium battery on my van. The EBL-211 does not have a Lithium profile charging so I have removed the 240V power supply to this to prevent it charging.
This works all ok, I do not need lithium charging as I have 300 watts solar and a 30 A B2B.
But I loose a few things
I loose starter battery charging when on EHU (I could install a cheap charger to overcome this)
I loose EHU indication (not a major issue)
I loose the 12v load running on the EBL rather than all on the battery when on EHU
So I was thinking of installing a 240v relay to disconnect the lithium from the EBL when on EHU. This will allow the EBL to charge the starter battery and the EBL to take on the vehicle loads.
My question is can the EBL take on the vehicle loads without the leisure battery connected. The EBL has a 20 amp fuse coming out the charger and a 30 A fuse on the battery input. I am thinking that on EHU the EBL and leisure battery share the load, when high demand the battery takes up the slack and when low the EBL take on the work and charges the battery. If this is correct then installing the 240v relay would not be a good idea
If this is not a good idea then is there a lithium charger which will also charge a lead acid starter battery.
