Easy engine pre-heater fit?
Cardiff, UK
Since 2016
A couple of years ago I fitted a heater under the diner bench seat. Heater matrix fed with water by tapping into the cab heater pipes under the bonnet and twin 12v fans providing the airflow. It works really well.
I'm considering fitting one of these 2kw engine pre-heaters for better starting in the winter.
My question is, for ease of installation can I just connect it into the same pipework under the bench or will the thermostat prevent the hot water circulating around the engine. Its a
Peugeot 2.5td if that makes any difference.
Hi..ive done similar on a ford transit with a hydronic diesel heater.. I plumbed it into the existing heater heat exchanger pipework...
There will likely still be circulation round the engine block..the thermostat will eventually open opening up the radiator circut..
Odly enough my issue was stopping the engine heating up when I was running the heater while parked and only wanting van heating or hot water.. I had to install a solenoid valve to prevent flow round the engine block...
If you are just installing it as an engine pre heat device what you propose sounds OK to me..
Andy
At 2kw you would only be able to use it when on EHU and then the outlet would need to be 10amp.
I have a similar one.
I only use it on really cold mornings though.
It works pretty well, but you can’t beat a diesel heater.
I used to love the “rest” function on my older sprinters, not sure why Mercedes remover it. Oh, and my previous sprinters either had a diesel add heater. That could be converted to a pre-heater/standing heater. Or the PTC electric boost heaters
Cheers guys, I'm reassured that it should work so I'll give it a try. Worst case I would just need to re-plumb it to the engine side of the thermostat. I only want it for really cold winter weather when I've parked up for a few days walking or skiing. In both cases I would be on winter campsites so 10 amps won't be a problem. 👍
Plumbing into the heater side of the cooling system is the way to go, the thermostat won’t open until 88C/90C so the hot water will only warm up the engine, ( exactly what you want)
I have a Kenlowe hot start on my old Land Rover and it works a treat, same principle,
