Just want to check something please.
Am I correct that when you dont have an EHU the water/space heater has to operate on Gas ( ie doesn't work only from battery)?
Only picked up the MoHo at the weekend and seem to have forgotten bits of the handover......
Just remember the heating needs a small amount of 12V power from the battery to run the control module that switches it on and keeps it going. If your battery is totally flat, the heating won't work on gas - neither will the fridge.
Hi Stevie and Welcome.
Just a reminder whilst on the subject of water heaters - with you living in Scotland make sure your water heater and all pipe work is fully drained down. We are starting to get early morning frosts down here in the south and normally it’s that bit colder up your way. Frost damage to motorhome water heaters is not a cheap fix.
