Battery is under cab floor not in the engine baythanks for reply the kit I have does connect to the light cluster but needs live from battery to bypass electronic system, I have looked all over dash to find a way through never thought of under batter,y thanks
Battery box is longer than the battery so easy to drill a hole if there isn't one alreadyye the battery is in the cab I am trying to find a way to get the live from there to the rear light clusters/tow bar as I cant find a way inside of the van being careful not to upset the van electronics
I'm suprised that worked without throwing a canbus error.I recently fitted a tow bar to aPVC - same model as yours but later version, power was took from rear light cluster so as ignition is turned on power is automatically at the towbar electrics
I asked the question -but the guy who fitted the towbar had a little note book that he followed the wiring fromI'm suprised that worked without throwing a canbus error.
The towbar came with a small box for the wiring - inside the box was some electrical stuff that allowed the electrics to work without any canbus errors.I'm suprised that worked without throwing a canbus error.
