Ducato indicator warning buzzer inaudible
Belfast
2001 Hymer, Ducato 2.8jtd
Since 2009
I have a 2001 Hymer B544 / Fiat Ducato 2.8 jtd with what I hope is a simple problem to solve. When the indicator switch is turned on the "click" or "buzz" to indicate the indicator is on is so faint that it is easy to drive for some distance before remembering to cancel the switch. The switch is self-cancelling after going round a bend but not so when overtaking or switching lanes of traffic. The green warning light on the dash is not very visible in bright daylight.
Is there some kind of relay or replacement switch that I (as a non professional auto-electrician) can fit that would give a louder audible alarm?
I have the same problem…………..the Duchess says it’s me lugholes! :ROFLMAO:
Thanks Jev88. I tracked down a replacement relay from sales@classiccarleds.co.uk which was advertised as having an OE clicking sound. I drilled a small hole in the casing (after removing the contents) at the vendor's suggestion and fitted the new relay. The section of dashboard in front of the relays incorporated a very thick layer of sound deadening material so I removed a square of the felt that was up against the flasher relay and this also seems to have made the click more audible.
I put buzzers in the instrument binnacle, nice and loud, A’SAY NICE AND LOUD :giggler: :giggler:
A pound apiece off eBay.
