Ducato headlamp beam level - problem with beam height
GrahamCardiff
Cardiff
PVC Sunlight Cliff
Since 2018
Hi,
I've got a Ducato 3.5t Sunlight Cliff PVC, 2018 reg. Has anyone had any problems with lowering the beam sufficiently to not dazzle other drivers? I've set mine to 3, the maximum lowest beam setting, and it's still to high. I can't shift any of the load weight to the middle. My garage says the bulbs can't be manually adjusted.
Any solutions out there, please?
Graham
Lbvisly they haven't got a clue, there should be a couple of adjusters on the back of the lamp housing one for horizontal & one for vertical adjustment.
I assume it was at the correct height for the last mot, what has been changed since then to make it high ?
I had a faulty bulb on my wife's car, beam angle was way out, new bulb and passed mot.
The bulb can not be altered, apart from not fitting it correctly. But the headlight can, and should be aligned properly. They often don’t bother to check, adjust headlights on MOTs
This has just reminded me, having finally fitted rear air suspension assist , now would be a good time to check the beam alignment. Any idea what .5 bar difference would make to ride hight on a Ducato. Started off at 2.8bar whilst towing. (From previous threads on mhf)
