DBK
My left hand door mirror is having problems folding electrically. The driver's side one folds in smoothly but the passenger side one will only fold if gentle hand pressure is applied, in both directions, folding and unfolding.
I have worked a silicone grease into the "joints" from the outside, using a bit of string but though it possibly moves a little better it still isn't right.
I've taken the door mirror off but there didn't seem to be any non-destructive way to take it apart. There is a foam rubber pad or gasket stuck on the part of the mirror which fits against the metal door. Does anyone know what I might see if I remove this? I am trying to get to the motor and gearbox and the pivot shafts, if there are such things and see what I can lubricate.
There isn't a lot of room to work as there is a cable coming out of the door with no obvious way to disconnect it.
Any thoughts on dismantling the door mirror and whether any one has come across a sticking mirror and been able to cure it would be appreciated.
