Ducato 250 front rain gulley
Cambridgeshire
C class
Newbie
on our Autotrail tracker EKS 2009 the front gulley under the windscreen drains via a rubberised pipe from under the bonnet in front of drivers side bulkhead. It then exits via the offside front wheel arch. My issue is this pipe is marginally short of where it mates up to the little stubby pipe at the top end. Previous owner used tape to secure and extend it. Is there a manufactured piece that bridges this gap or do I need to fabricate one ? In essence the top of the downpipe is about one inch short of where it should go over the stubby exit pipe from the gulley. Can anyone advise please.
worcester
Sunliving van
Mine fell off as well. Apparently that can lead to water in the power steering reservoir which you need to check.
Just pulled it back up and added a jubilee clip.
Even now when I check the oil I always check it's still in place.
Badknee
notloB
Vantage Neo
Living the dream.
I think there’s been threads on here about this problem, try doing a search. (y)
Pagen
Cambridgeshire
C class
Newbie
I have tried “pulling it” gently so to speak ! However it still does not quite reach far enough to clip it. Should I try pulling it harder !
worcester
Sunliving van
Look at the other end to see if its seated properly.
Otherwise pull it at your own risk.
