Hi, i want to fit a dual control solar panel regulator, can anyone tell me the correct size of cable to use and what size inline fuse. I am led to believe the fitting is fairly straight forward, one wire to the vehicle battery and one to earth!
Stick 2 panels in series and run a 24v regulator then charge your 12v from the 24v.While we re on this, my hab batteries are 12volt and my chassis batteries are 24v, can anyone think of an easy way to get a cable to charge the chassis batteries from the regs that are already charging the hab batteries? Could be one you you martin funflair ?
I said easy Martin not £366, how will I get that past the management?Stick 2 panels in series and run a 24v regulator then charge your 12v from the 24v.
We can do that next week Jon.
Sterling BB241235 'Pro Batt Ultra' Battery-To-Battery Charger - 24V/12V 35A
Sterling Pro Batt Ultra multi-stage BB241235 Battery to Battery charger. Euro 5/6 smart alternator & regen braking compatible. Ideal for 24V horseboxes.www.12voltplanet.co.uk
Switch your inverter on and charge with 24v chargerI said easy Martin not £366, how will I get that past the management?
That looks ideal. ThanksSterling 12V to 24V battery maintainer? A lot less than £366.
Battery Maintainer
Instruction Manual PDF Product Information PDF Battery maintainer / charger includes 1m of cable.Save money on batteries and stop them from being destroyed by discharging. A flat battery means you need an expensive replacement.The auxiliary battery charger maintainer is simple to install and is...sterling-power.com
