Really like the look of this van but disappointed that only the passenger seacan be turned.Can the drivers seat be adapted so that it it also can be so you can have another littlevseating area up front.
PI80 Universal Turntable. These swivel turntables are universally handed - they can be installed as driver or passenger side seats. Expert advice on seating solutions and seat information. Should fit a wide variety of vehicle applications.
www.ebay.co.uk
something like this
French manufactured, the RIB swivel plates are a very popular choice with campervan self-builders owing to their solid construction and smooth mechanism. The swivel plates fit between the base and seat slider rails on normal seats and pivot on a centre location point. The swivels have European...
My previous van had swivel seats for both the passenger and driver. Immediately behind the driver was a unit that contained the fridge, so there was no point in turning it much beyond 90 degrees. So with the handbrake (that had to be down to swivel), the arms on the seat (meaning you had to slide forwards and then backwards to clear things), the steering wheel that was always at your elbow and the cabinet behind, it was rarely worth the hassle of turning it.
Also note that the after market swivel bases add a few centimetres to the base height. So if you're short, you might find the seat is now higher than ideal.
Is there enough room having the bathroom behind the drivers seat, we are on our second panel van conversion and both you have to lower the steering wheel and adjust the slide in and out because of the handbrake.
If you feel your calculations will work crack on. Bob
