The plastic retaining clip at the bottom of the flyscreen door (sliding bit) has broken and I need to repair/replace it. It looks like I need to remove the whole frame and this means getting the step edging out (the U shaped bit at the top). I've removed the two screws but don't know how to pull it away as there appear to be hidden clips. The flyscreen frame will not come away unless this U shaped trim is removed. It's a 2015 model T660 Nexxo but similar aged Nexxos are probably similar.
Has anyone had a similar problem with a broken bottom clip on the flyscreen sliding door?
