Do you have Oyster and Sky+ ?
  • Thread starter Thread starter Xoxoc
  • Start date Start date
X
Xoxoc
If you do, how do you use it? Do you have a twin lnb or do you just use the standard one and if so how do you use the recording function etc.?
Bryan
Bryan
Has something finally beaten your very good technical brain:Rofl1::Rofl1::Rofl1::Rofl1: welcome to my technofobe club:BigGrin:
:Rofl1::Rofl1:
Of course not Ruth :Wink:
Just hoping to check what I know with some-one that is actually doing it :whistle:
Bryan
You need the twin LNB to record & watch another channel or record 2 channels.
When I had the system fitted I found I was only getting one feed to the Sky+ box despite having twin LNB.
You have to press AV or F1 on the Oyster remote depending on which one you have. That gives 2 feeds to the Sky+ box.
I also find that I need to have both feeds to get all channels on the Sky box.
I'm not too bothered about recording one channel and watching another - nor recording two things at once, unless of course it is simple and cheap to upgrade to twin lnb :BigGrin:
Just want to know what I can do with one lnb, which input is best to conecct to on the sky+ box and if there is anything special to do :Wink:
Hi Brains
the answer is quite simple
if your not willing to upgrade to a twin L:NB then your sky + box can only be used as a normal skybox, no recording and one channel only via LNB 1 on the back of the box, as you know I have the superior Crystop system :RollEyes:and a sky -:Rofl1:
Geo
I have been looking at buying an automatic dish for our SKY+ box, Oyster etc
I've been told the Kathrein’s system as twin LNB but the dish uses one of the LNB to alignment purposes, so this is no good for sky+
Right now we have a standard 43cm sky dish and a tripod which we use with the SKY+ HD box. One of the 2 inputs is used for the EPG and the other for the second recording as previously mentioned.
I am buying the Crystop dish, i recommend RoadPro .I contacted many vendors on this topic, some replied, some didnt, but I have exchanged many mails with Andrew Harris of RoadPro on the topic of SKY+ and automatic dishes. These guys really know their stuff!
N&K
Hi Brian
Just had sky plus hd fitted to our van.If you only have a single feed lnb as you say you cannot do 2 at once but it is an easy set up,connect the sat feed to input 2 then go into settings and select single feed.Hope this helps.
Pete:thumb:
You can still record using a single feed to a Sky+ box, but it takes some extra planning.
Anything that's scheduled to record will default to the feed that you're not watching (i.e. the one that doesn't exist) so you'll get a failed recording. To get around this you need to schedule a recording that you don't need to start before the one that you actually want to make, so that the Sky+ box will be forced to use your live feed. Hope this makes sense.
off topic if any one wants a nearly new camos dome then contact rob on 07800591216
he wants £800 plus fitting charge if you want in fitting.
rob as just been today and fitted a camos plus for me ,he is recommended by roadpro.
did a first class job today.:thumb:
