We’ve recently purchased a Weinsberg Carasuite and now looking to fit a cycle rack for 2 bikes. There’s nothing in the very generic owners handbook about strong points or max load on the back wall. Weinsberg’s website doesn’t seem to have much technical info or access to a technical helpline, so I did a bit of web searching and found pictures of a Fiamma carry-bike CL fitted to the same model as we have and ordered one. As far as I can tell the back wall just seems to be just an aluminium/polystyrene/hardboard sandwich, so I’m reluctant to get the drill out! There is an aluminium rail running the full width across the top of the garage which supports the wardrobes and bed above, should I try and put the rack’s top mounts through that do you think? It will make the rack higher than I’d like but if it makes the difference between staying on or ripping the back wall off, the inconvenience will be worth it! Anybody else done a diy fit?
I realise a tow bar solution would be a better option but was hoping to avoid the high costs that would involve.
Any comments or advice greatly appreciated.
Mike
Mike
