Hi Guys. Want to hard wire my dashcam in 2020 Fiat Ducato. I require a switched live and a permanent live. Can anyone recommend which fuses to piggy back in fuse box at drivers right knee. Want to avoid going into engine bay if possible. Appreciate your advice and help as usual.
Hi, Hoping to fit a ignition-fed 12v power supply to my SatNav via its 5v stepper using a piggy back fuse from a source in the Cab Fuse Box. I took out the two screws securing the top of the under fuse box panel but that panel (occupying the space between the lower dash and the foot pedals)...
Hi I’m currently wiring a reversing camera and monitor , is there a ignition switched live somewhere within the dash I can use? This is a fiat Ducato 2019 model. Thanks
