Damaged Window Autotrail Vline
Looking for replacement window maker within west yorkshire any ideas.
The maker should be stamped or printed in the top right hand corner, luckily not the one you broke. If it is the same as mine, you cannot buy direct. Either contact Autotrail, quote the maker, and they should be able to help. They couldn't with mine, but you could be lucky, as a friend was using this route. Or your dealer. I think mine was something like Plasform, from Holland or Belgium.
Did the sliding door whack it ?
Bad design really.
Yes that is what happened. The window should be fixed not opening.
