Czech Republic - Go Box Equivalent
Edinburgh
Rapido 881F
Since 2015
We are bigger than 3.5 tonnes so need a Czech equivalent to the Go Box. Has anyone done this and where did you get the box from please?
I understand that you need to go to distribution point but we can't find a map with them on and their system isn't quite as slick as the Austrians for finding where they are.
Any help gratefully received or we could just stick to Austria and Germany if this get too hard!
We got one of the boxes about 5 years ago, called "premid" I believe, we found the process quite simple but I know others have had issues, one thing to bear in mind is that they will return your refund the same way as you pay it so if you use cash they will give you cash back, easier to put it on a credit card (we didn't have Revolut then)
Thanks funflair our problem is trying to figure out where we can pick one up, they seem to have a list of distribution centres but no map, which is a tad challenging!
When we went , also 5 yes ago, all the motorway service stations had them. It was easy.
Just remember to cash it in when you leave at the last place prior to the border. Unlike us
Use the map https://mytocz.eu/sites/default/files/2022-12/Map_toll_network_from20230101_0.pdf to show distribution points in the green box,
You can then find the box number in the table and it gives co-ordinates, https://mytocz.eu/sites/default/files/2023-06/CP_DP_list_6.pdf use the D number from the map in the table and then search for the box/distribution point number
For example I went to D6 and found 4114 and 4115 which are different sides of the motorway as you either enter or leave so be careful.
Thank you so much for that funflair , we spent ages looking for just that. I knew Motorhome Fun would come up trumps!
